Trike conversions....who's the best?
Lehman trikes maybe?
They have been converting 2 wheels for sometime. Harley used them for a year or two. Learned the how to and then went on their own and kicked them out. Or something like that.
Other may chime in who know more then I do regarding this info.
Also, may get more info n the trike section.
Good luck.
YB
Good luck.
YB
Seems there are some that know nothing about trikes chipping in on their opinion. Lehman, Frankenstein and Mystic??? (Mystery maybe) are NOT the best. There is nothing wrong with them but saying they are the best is like saying Ford or Chevy is the best when Rolls Royce, Mercedes, and others are around. My opinion on who is best is somewhere between Roadsmith, CSC, Champion, and Hannigan. Those are the 4 MAJOR players in my book. There are others like DFT that make good trike kits too. Lehman is a Harley with a different name and even though they have been making trikes a long time, they are not the best. They were about the last to finally come up with a IRS suspension and they didn't do that till Champion bought them out. As I said, there is nothing wrong with Frankenstein or Lehman, but they are not the best. If you are seriously looking to convert, take everything into consideration. Get a raked tree for the front, think about getting reverse (mechanical, not electric), and test ride some and see if you prefer IRS which I personally think is great, or if you like solid, or if it even matters to you. Think about the length and width. All are NOT created equal. For example, the CSC is a long trike. The rear axle is BEHIND the passenger rather than under the passengers butt. Longer and wider = smoother ride. IRS vs solid. Full body or not and who works on which makes in your area. Those things, plus your finances will lead you in the right direction. Do it and don't look back. You won't regret it. One thing I will caution you about. Avoid getting pieces parts and doing it yourself. Get a kit. That way you know all the pieces work together. When you buy a kit, you can option the hell out of it too. Lights, trunk liners, rakes, reverse, bras, bumpers, wheels, paint choices, etc.
Well, I'll jump in here with this: The largest producer of trike kits for GoldWings is Motor Trike. They are the second oldest manufacturer, behind Lehman. The others came after. So, I would certainly call Motor Trike one of the best. Long wheelbase does not automatically guarantee smoother ride. It can, however, make the trike more cumbersome in tighter spaces. It's the suspension that contributes the most to how the trike handles and rides. Read articles, visit websites, ask owners. Investigate and choose carefully.
I would suggest you add in the expense of changing your rear sprocket and belt along with the possibility of the front sprocket to raise the rpms needed to make 6th gear usable riding a trike.
If your 09 has the 32/66 sprockets and belt, your 6th gear will be almost useless unless your riding on flat roads. You will want at the minimum 32/70 ratio. Better yet 30/70 will raise the rpms and give you more usable power in both 5th and 6th gear on the highway for both passing and climbing the mountains
As said do the research prices for full conversion come in close to each other. You do want raked tree and reverse for sure add to the cost but worth every penny. I have a 2008 Champion on my 93 FLHS love it. Straight axle dual disk brakes and very sure footed in the corners. Reverse I do not use to often but when needed glade it is there. After you decide which take a long look at where as the installer makes all the difference in the end.
