Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have no spark to my plugs so I'm gonna get a new coil first before I try other things unless you suggest a cheaper option to try first my issue is I don't know if I need a dual or single fire coil what are the pros and cons to them input please
I took the wire off the plug and put a screwdriver in it put it to bare metal and there was no spark... I'll try to get a pic of the coil to see what kind I have new at all this I don't know what you mean by leads
the smaller wires that go to the coil ( not the thick ones that go to the plugs) if there are two then dual fire, three is single fire. Do you have access to a multimeter?
