SEPST Map for 96" with Andrews 48H cams
Hi All,
Chasing a SEPST map for a stage 1, 96" with Andrews 48H cams.
The bike is a 2010 Softail Custom with SE a/c and SE Double Barrel exhaust. I live in a regional area and don't know/have any tuners nearby, so help would be really appreciated. Thanks.
Regards Rowdy1
Regards Rowdy1
Don't know if you had any luck, but there is a tune in the SESPT which is similar (uses SE255 cams).
Could be used as a base map, pretty lean though.
358SDX002
Don't know if that number helps, I'm new to this.
I'm looking for a map just like yours too, as a base to use.
Update 9th July After a couple of Smart Tuning runs, the bike is running well. A few more and some tweaking it should be even better.
Not easy (impossible) to populate all the cells by riding on the road. Interpolate button/key is your friend here.
Dyno tuning as suggested by HD still offers the best possible result.
358SDX002
msr082881
02-20-2015 04:28 PM
