Se203 map
Old Apr 9, 2015 | 05:35 PM
Jeckel's Avatar
Jeckel
Default Se203 map
I am wondering if anyone out there might be able to help with a map for a pc3-usb. My current setup is as follows:
2005 flh 88CI
dealer stage 1 flash
SE Intake
SE 203 cams
Rush 2 -1 exhaust
The map I got from dynojet doesn't work very well, and I get terrible mileage. Especially above 3K rpm.
Old Apr 11, 2015 | 08:33 PM
misfitJason's Avatar
misfitJason
When I had my Pcv I just dgot wnloaded a map from the DJ website. you need to search different bikes in their search function at the map lookup page and maybe find one for a softail or touring bike. Get a map for the right cams and maybe the thunderheader. It worked pretty good on mine
Old Apr 13, 2015 | 02:20 PM
Jeckel's Avatar
Jeckel
I have looked through their site, and it seems as if no one else in the world has ever used se203 cams with an 88" motor. Only the 95"... (sarcasm)
Old Apr 13, 2015 | 04:49 PM
Big Money's Avatar
Big Money
If you call them they will send you a map for any combo you have.
Old Apr 13, 2015 | 09:53 PM
misfitJason
I looked and found about ten. You just might not be able to find the same exact year or family
Old Apr 13, 2015 | 09:54 PM
misfitJason
Oh my bad. Those are pcv maps. I don't know if that makes a difference
Old Apr 14, 2015 | 11:44 AM
Jeckel's Avatar
Jeckel
Just a little difference... PCV and PC3 are totally different files.
I didn't see one map for an 88" motor with the se203 cams. Perhaps you can give me a map number?
Old Apr 14, 2015 | 07:52 PM
RA51's Avatar
RA51
hdtech@powercommander.com
E-mail them you info on bike an they will send a map.
Old Apr 14, 2015 | 09:21 PM
misfitJason
I really don't know what website you are looking on and not finding anything but here are some maps I found from powercommander.com
map numbers
805-056
Khrome Werks full exhaust, Stage 1 ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Khrome Werks full exhaust, Stock ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Cycle Shack tapered slip-ons , Stock ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Cycle Shack tapered slip-ons, Stage 1 ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Vance & Hines Longshots (without baffles), Stage 1 ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Vance & Hines Longshots (without baffles), Stock ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Vance & Hines Longshots, Stock ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Vance & Hines Longshots, Stage 1 ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Vance & Hines Straightshots, Stage 1 ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Vance & Hines Straightshots, Stock ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Vance & Hines Straightshots (without baffles), Stock ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Vance & Hines Straightshots (without baffles), Stage 1 ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Vance & Hines Shortshots (without baffles), Stage 1 ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Vance & Hines Shortshots (without baffles), Stock ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Vance & Hines 2:1 Pro Pipe, Stage 1 ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Vance & Hines 2:1 Pro Pipe, Stock ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Python 3 full exhaust, Stage 1 ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Python 3 full exhaust, Stock ECU, Screamin Eagle 203 Cams and Screamin Eagle air filter
Old Apr 14, 2015 | 09:25 PM
misfitJason
There is none listed specifically for Dyna but you can use a map for a softail or touring as long as the components somewhat match. I have never found a map for a rush 2-1 specifically but the thunderheader or pro pipe has been pretty close. Get creative and do some riding to figure out which one works the best. When my dyna was 88 I used the thunderheader 2-1 map for pcv. All the maps above are pc3 maps
