replacement fuel pump
2002 Softail Springer
Having a rough start to the riding season!
Last fall I was having some issues with hard starts and sputtering and '*******' out at highway speeds. Thanks to the forums here I found out it was the fuel line pinhole issues. Got the tank opened up and assembly out of the tank. Found that the liner was flaking up in the tank. Bike had a dent and some scratches and chips, so figured what the heck, tins are at the paint shop waiting for some paint and airbrushing.
So now I'm working on getting everything ready for re-assembly. Got the new fuel filter and HD's "fix" for the cheap hose(same plastic hose, just an inch shorter). Was taking the old hose off, everything was kind of brittle, and broke the stem off the fuel pump. Stopped at the dealership and found out Harley does not sell just the pump. Have to buy the whole assembly at $250!!!!!!
Been searching the net a bit and found some replacement pumps at way cheaper. My question is, does anyone have recommendations for a replacement pump????
i REPLACED MINE
I broke the nozzle on the stock fuel pump for my 01 Fatboy while replacing the fuel filter, the pinch on metal clamps suck.
could not find the same replacement a Denso AF195130-6390 .
I could find similar Denso 195130 that go in a toyota, or ford they probably work fine dont know
I also got the Highflow on ebay. I didnt want to get the $9.99 ones or the $14.50 ones, just think there has to be something wrong with those
It seems to work fine at all speeds and starts well but doesnt quite have that pop when your at freeway speed and need to pass or do some kind of hard acceleration move.
I am thinking about replacing it but since I cant find the actual replacement I came her to see if anyone had some other info
Note -one of he reasons i went in to replace the fuel filter is because the bike was coughing at low rpms. This actually turned out tO be a pin hole in one of the fuel lines.
