Check Engine lamp persists - Code P0113, Delphi EFI system...
Continuity was normal while doing wiggle test between ECM and connector 89B so I'm skeptical but Ill persevere on the presumption that wiring is the culprit.
I still have to Ohm wires 7 and 26 which will demonstrate if anything is rubbed out within the main harness somewhere - This would be a the most costly fix :-/
I have checked the calibration for the IAT Sensor and it's within spec (530@160F).
The schematics and manual information you have posted above Bill are critical to the understanding of this issue and any future resolution to DTC P0113 which other members will encounter - my hats off to you and everyone else who have contributed so far :-)
