Coil
Mate...Good on yah for getting a Shov, but if you cannot tell what coil system she is running then you in for a power of pain looking after that bike!
Does it have one or two coils? if two then thats your answer. if it only has 1 then does it have two wires to it, or 3 or 4? If 2 wires then its a normal duel fire, but if 3 or 4 then its most likely single fire.
Stock and about 99% of the shovels out there are thew normal dual fire, easiest way to tell is check what ignition system you have in her and post back and we'll be able to tell you. Single fire systems usually have 2 coils or what's called a split coil and it's kinda obvious as it's on the big side and like another post mentioned you'll have more wires going to it on 3 or 4 terminals instead of 2.
Coil
tymatt67
09-23-2012 08:54 AM
