Fuel line leaking
Old 03-09-2009, 07:51 PM
Bogey_52's Avatar
Bogey_52
Bogey_52 is offline
Default Fuel line leaking
2 Questions
1 - I'm getting fuel dripping from the swivel joint on my fuel return line at the tank. Is it possible to separate that fitting to get to the internal o-ring, or do I have to buy a whole new fuel line?
2 - And do the internal tank check valves actually work? Mine leak continuously till the tank is empty every time I take off the fuel lines. I'll buy new ones if I think they will work.
Bike is a '97 FLHTCI. Thanks for your advice.
Bogey
Old 03-09-2009, 09:29 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Shovelhead Bob is offline
The in-tank fitting is not repairable....
Only way to damage it is by not installing the fuel line squarely into the fitting.. thereby gouging the internal o-ring.....
FWIW, the MM fuel tanks were notorious for this by repeated R&R of the fuel lines...
Old 03-09-2009, 09:43 PM
Bogey_52's Avatar
Bogey_52
Bogey_52 is offline
Thanks for the info Bob. I'll just buy a new line and watch how I assemble the fittings.
Old 03-17-2009, 11:08 AM
mainshaft's Avatar
mainshaft
mainshaft is offline
I have an 00EGC and just bought new lines/check valves. I'm going to replace them this weekend after I run some fuel out of the tank.
randazlr
13
07-13-2017 10:36 AM
Rocklobster707
06-15-2017 02:50 PM
cptseawolf
02-26-2017 03:49 PM
kjelders
06-22-2012 03:43 PM
mile hi
10-23-2007 03:31 PM
Quick Reply: Fuel line leaking
