Installing the Coyote Quick Disconnect fuel fitting
Old Jun 22, 2012 | 11:45 AM
kjelders's Avatar
kjelders
Default Installing the Coyote Quick Disconnect fuel fitting
Any problems with just cutting the existing cross-over fuel line and inserting the quick disconnect? On my 07 Ultra, the cross-over fuel line is a black braided fuel line. I would only need to buy 2 fuel line clamps and walla, all done.
Old Jun 22, 2012 | 12:45 PM
FLHTCU Owner's Avatar
FLHTCU Owner
No problems at all. Just make sure you have something to catch the fuel before you cut the line. Even if you siphon as much as possible, you'll still have some fuel in there.
You'll have to cut the crimps as well, otherwise you won't get the line off of the nipples from the tank. That's what I had to do anyway.
Old Jun 22, 2012 | 03:43 PM
kjelders's Avatar
kjelders
I'm not planning to take the fuel lines off the tank nipples. After what fuel drains after cutting the fuel line, I will insert the quick dis-connect with two new clamps. I just don't see any need to replace the black braided fuel line that is already there.
ultravista
Mar 1, 2017 12:47 PM
Alain
Oct 13, 2014 03:19 PM
KrustyHD222
Oct 19, 2012 11:33 AM
deke
Carburetor Related
Sep 18, 2012 08:35 AM
straightleg
Oct 8, 2011 02:14 PM
