Won't start after removing switch housing
Old 08-12-2009, 09:04 PM
zgodwin's Avatar
zgodwin
zgodwin is offline
5th Gear
Default Won't start after removing switch housing
I have a problem that I hope you HD gurus can help with. I have a 07 Ultra and trying to save a buck I tried to change out my stock black switch caps for the chrome kit myself. ( I know, should have taken to the dealer)
After changing the caps and putting everything back together it will not start. Seems like a problem with the run/stop switch. Switch travel is OK but I do not hear the fuel pump when I turn the ignition on and am unable to start the bike. The security indicator is on solid (even though I do not have the security system installed on this bike). I read the DTC codes and I get: P node no_rsp; S none; SP U1064; T none. I examined the wiring for to see if I pinched a wire and I did notice that one of the wires that come from the run/stop switch was knicked. It does not appear to be broken, just pinched, and it would not have touched bare metal since it was inside the plastic sheathing. I also noted that the turn signals do not work (either one).
Couple of questions, Does replacing the run switch involve replacing the entire wiring/switch harness or can you just replace the one switch and wiring? Does the no_rsp P code mean that the ECM is shot or just that the run\stop switch is not working? Is the turn signal problem related the the run\stop switch/ecm problem?
I know I am going to have to load my dead bike up and take it to the dealer but would like to get an idea what kind of damage report I can expect. I think trying to save a buck by changing my switch caps is going to turn out to be an expensive decision.
Thanks in advance,
Zack
Old 08-14-2009, 03:11 PM
zgodwin's Avatar
zgodwin
zgodwin is offline
5th Gear
Problem turned out to be a blown fuse.
Old 07-12-2012, 09:32 PM
cadman444's Avatar
cadman444
cadman444 is offline
Stage III
Hey Zack...just read your post about changing the switch housings out...I know this is a pretty old post but the same thing happened to me...so it turned out to be blown fuse huh? which fuse was blown? Believe me, I was freaking when I flipped the run switch and nothing happened. Any info would be greatly appreciated.
Mike
Michael Haz
2014-2023 Touring Models
22
07-25-2019 12:38 PM
Jayson Auxt
Electrical/Lighting/Alarm
07-20-2015 08:13 AM
Gommee
06-27-2012 01:28 PM
onemyndseye
01-07-2012 09:55 AM
sutphen30
Ironhead
06-09-2008 07:03 PM
Quick Reply: Won't start after removing switch housing
