Help with Thundermax tuner
i have a 06 Heritage with SE 103 Stroker kit and Thundermax. I bought the bike used with all this installed. i have a warranty thru Harley Dealership. I went to Daytona and the bike ran great until last day. It started having a miss or stumble while cruising. It runs fine under acceleration. I took it back to Dealership and they called and said they could not fix it they did not know anything about the Thundermax. The warranty states they will fix anything for $25. So I am at a loss. I have done some research and I think it could be a o2 sensor. What are your thoughts? Thanks Dan
i took the bike to dealership because it is under warranty and have not went back to get it yet, i bought it with all performance mods already done. The other prob. i do not have any of the things that came with the programmer. i have the previous owners ph # and i am gonna call him and Zippers when i get back home. thanks for help.
It sounds like the o2 sensors are bad . At least one of them . They are fragile things . I replaced both of mine over the summer . The bike ran just like you described . After replacing them , the problem went away . And you DEFINITELY need the software and tuning manual for the T-max . Even if you have to buy them new from Zippers....do it ! They are invaluable . Here is a link to the correct sensors . Don't waste your money buying them from Zippers . They will charge you double what they should cost .
http://shop.advanceautoparts.com/web...730616-P_291_R
Down load and read the manual now
http://ssdl1.cachefly.net/ThunderMax...9.pdf#view=fit
Al
The software can be downloaded on Zippers, the manual is included in the help drop down, you will need to buy a usb adapter also available from Zippers. Some other adapters don't work, pay more but buy once.
Al
Al
I destroyed my o2's with assembly fluid when I did the 103" BB conversion.
Al
thanks everyone, i have been out of town at Cont Ed classes. i go home tue and will pick my bike up wed from dealership and find out if i can submit charges to the warranty things like this is why i bought it. the o2 sensors are $104 should only cost me $25. i will get the manual and correct usb. I will change the 02 sensors myself. Bike ran great before I feel sure prev owner had it dyno tuned so the maps should be good. thanks again for all your help
