Power Vision Information Thread
#7391
#7392
Need advice,, I had my dyno done and finally bike runs well and found someone that can tune with my PV. I have a 107 build . I did lose about 100km about 63miles to a tank compared to a stock 103"... I'm wondering if I can make a highway cruising Map with just lowering the VE table valiues by 4 at throttle position from 30-60% at rpm 2250-3000rpm or change AFR table to 14.5 in those ranges.. Do I just change AFR table and leave the VE table of both front and back cyl alone ? I assume I will lose some power and throttle response if I do this but really would like little better highway mileage on long trips.... Any suggestions? I an running open loop so stock oxygen sensors not used and I don't have AT which I wish I did...
#7393
Using EITMS control located in the tweaks section of the PV
OK am I correct with the assumption that turning on the EITMS control in the Tweaks section of the quick tune section of the PV, I can turn on the ability for the EMC to shut fuel flow to the rear cylinder for cooling during idle to keep the rear cylinder cool?
I know my 2012 Fatboy has this capability and it can be turned on and off by the dealership. But is this EITMS the same capability?
#7394
Yes. You can also tell it what temp to turn on. Or disable it by setting temp way high like 560.
#7395
Leave the VE's alone (you paid good money to get em right) You can set your AFR anywhere you like. I.E. cruising at 14.4 = good milage.
#7396
#7397
The PV wire is routed the way FM told me to route it ( under the console and not under the tank) It is not pinched as I can slide the wire around, key fob batteries replaced and the fob is normally in my pants pocket or my jacket pocked.
The firmware and the data base are both up to date
I did not get the chance to rerun the cable yet and that is my next item. Pull it out and not have it run near anything.
On my '13 FXDWG I run the cable above the tank (under the the tank bib/chrome molding where the power and speedo are mounted), then I snake it under the seat. It was a bit of a pain to finally get it done, but, I haven't had and connection issues with it.
Also, check the power/connections to the ECM as well as the "alarm" system. The fob batteries are new now and still having the issue, so possibly that. The only time I ever had that issue was when batteries were dying.
Let us know how it works.
#7398
Adjust AFR table only, set the area of 30-70kpa and 2250-3000 rpm to 14.2 or 14.4. Granted, 13.8 will give you better power but 14.2-14.4 can be an acceptable trade-off on economy. You can also set your idle and low RPM/low MAP area to 14.2-14.4 but watch for increased engine temps if you do a lot of idling around town. Richer will lower ET's, on my town bike I run 13.1 at idle and just off idle.
#7399
#7400
For me it is PV related. Again removing the PV the issue never happens
I have provided several files and information to FM and they are going to contact DynoJet.
I went as far has routing the cable from under the seat along my leg up to the handle bars and it still happens.
