HD Code Reader
Old 06-23-2011, 10:44 AM
Inspector 12's Avatar
Inspector 12
Inspector 12 is offline
Default HD Code Reader
Thinking about buying a 32312-10 code reader. I know you can pull the codes from the speedo display, but the ability to clear codes by punching a single button seems more appealing than 50 key cycles to clear codes.
Anyone have one? Worth the money?
Old 06-23-2011, 06:08 PM
Little T's Avatar
Little T
Little T is offline
You can clear codes on the speedo. After reading the code press the odo reset button again. It will say clear. Then hold the odo button down for 5 sec. There you go!
Old 06-23-2011, 06:56 PM
Lonewolf176's Avatar
Lonewolf176
Lonewolf176 is offline
You can clear codes with your tuner if you have the cables.
Old 06-23-2011, 08:52 PM
Inspector 12
From what I understand, the method you suggest will clear a current code but not the historic codes.
I know I can use the race tuner (I do have the software and cables for both SERT and SEPST) but it seems easier to use a code reader than dragging the laptop out.
Old 06-24-2011, 12:24 PM
Little T's Avatar
Little T
Little T is offline
You cannot clear a current code until it goes historic
Old 06-24-2011, 12:35 PM
PistonPuller's Avatar
PistonPuller
PistonPuller is offline
Complete waste of money if you already have sepst software. Drag out the laptop takes how much effort???
markdavidson
Milwaukee Eight (M8)
09-19-2018 09:14 PM
Ezridr60
05-07-2015 01:29 PM
05dynaman
03-07-2014 09:19 PM
saw*me
04-18-2009 04:22 PM
J Short
Exhaust System Topics
06-11-2007 07:56 AM
Quick Reply: HD Code Reader
