Clearing codes
Old Sep 17, 2018 | 05:12 PM
markdavidson's Avatar
markdavidson
Default Clearing codes
2019 King
changed out the bars and have multiple codes... seems I cant clear them...procedure the same?
Old Sep 17, 2018 | 08:34 PM
CR3999's Avatar
CR3999
If you can't clear the codes, I'd go through the wiring again and make sure everything is right. There shouldn't be any other reason that I know of that you shouldn't be able to clear them.
I had a code go off once. I turn the freaking key on while the speedo was still disconnected. Good luck.
Old Sep 17, 2018 | 08:38 PM
markdavidson
I dont even get the " clear code" prompt...lights and signal work
Old Sep 18, 2018 | 09:48 PM
edmroadglide's Avatar
edmroadglide
i just changed bar and check engine light came on and stayed on everything else worked fine, went in with the tuner and cleared two codes and bobs your uncle all gone.
Old Sep 19, 2018 | 07:53 AM
markdavidson
I'm not sure why... but I tried it again last night and everything cleared out but one... BCM (b2106) not sure what that is yet
.. and yes the procedure is still the same, I just didn't have the sequence down... used to clearing through an FP3 that I had on my 16
Old Sep 19, 2018 | 08:28 AM
GlidingJoe's Avatar
GlidingJoe
Old Sep 19, 2018 | 08:30 AM
markdavidson
Originally Posted by GlidingJoe
YES.... But I have yet to figure out what that means
Old Sep 19, 2018 | 07:40 PM
Max Headflow's Avatar
Max Headflow
It means your running / fog lamps are not connected. Look for L4 on the wiring diagram.
Old Sep 19, 2018 | 09:14 PM
markdavidson
THANX good call. When I put my nacelle back together, the connector off the passing lamp switch got disconnected...I never checked to see if they were on
Chaseg08
Sep 13, 2012 10:46 PM
shuggy
Nov 4, 2011 06:39 AM
Agnes the dog
Jan 25, 2009 11:50 PM
Bama Harley
May 16, 2007 01:05 AM
KeithB
Exhaust System Topics
17
Nov 2, 2006 09:48 PM
