automatic or manual compression release
Old 02-21-2013, 10:21 PM
windycity's Avatar
windycity
windycity is offline
5th Gear
Default automatic or manual compression release
Need help, I'm installing a stage 4+ on my 09 crossbones, and harley says i should use automatic instead of manual compression release. Would like someone's opinion. Thankyou
Old 02-21-2013, 10:25 PM
Mark_H's Avatar
Mark_H
Mark_H is offline
My opinion is Harley is trying to up sell you. I have manual compression releases on mine. Seems like less to mess up to me and a compression release does the same job whether manual or auto. Only difference is you have to push the manual ones in by hand.
I'd save a few bucks.
Old 02-21-2013, 10:26 PM
windycity's Avatar
windycity
5th Gear
Thankyou
Old 02-21-2013, 10:29 PM
windycity's Avatar
windycity
5th Gear
Any idea how much less they should be? so i how much less to ask for. Thankyou
Old 02-21-2013, 10:32 PM
Mark_H's Avatar
Mark_H
Mark_H is offline
Going price for a manual release is about $18. Harley automatic releases are $40 each I believe.
Old 02-21-2013, 10:36 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
MCR's!
windycity's Avatar
windycity
5th Gear
That amount i can live with. I'm more concerned if there just as reliable as manual.
Thanks again
Old 02-21-2013, 10:38 PM
soft 02's Avatar
soft 02
soft 02 is offline
They are servicable. They hang up you remove them then clean out any carbon.
Old 02-21-2013, 10:43 PM
windycity's Avatar
windycity
5th Gear
which are serviceable? Auto or manual
Old 02-21-2013, 10:45 PM
soft 02's Avatar
soft 02
soft 02 is offline
Manual one's. As easy as pulling a spark plug. ACR's are in the center of the head under the valve cover. Not so easy to remove and clean.
Quick Reply: automatic or manual compression release
