Map change from 103 to 107 with head work
Had my 103 dyno tuned with SE Pro Tuner for 777s, air cleaner and exhuast. Just added the FM 107 big bore and level B heads. I have the cable and software and wanted to know if there is a way to update the existing map to accomodate the additional ci's and air flow prior to doing dyno or self tunes. I will most likely have it dyno tuned at some point but would like to update the current map before running it in this configuration. Am I over concerned with how running the old map will affect the bike? Can self tuning really get it close from the old map to now with the additions? Thanks!
j.r.1982 If you want you can PM also and will send to you also.
Hey just seen your reply to my issue and a map would be great man and much appreciated I don't know how to pm you but this is my email sharpen52@yahoo.com and thanks alot and my bike is a 2011 dyna with heavy breather kit and Vance and Hine slip ons With stock heads
