I need a map for a 04 flhtcui with 4.375 stroke 4.125 bore. Revolution nikasil cylinders,wiesco pistons, T-man stage 4 heads,58mm throttle body and 5.2 injectors by HPI. Boarzilla exhaust.
You are looking for a needle in a haystack.
Find a good tuner and pay to have it done. Maybe the guy who did your headwork can help you, beyond that you would have to find someone with the same work done to their bike, and then the same era injection system. Like I said, needle in a haystack.
Beat bet is contact the guy who did your heads. He may have donesomething similar for someone else in the past and if he does not have a copy of the map, he may be able to put you in touch with them. Or, you can contact dynojet and see what they have. When I did my build they "dynojet" were able to send me a map that was close so I could get it to a tuner, but all I did was add a/c, 26's and a v/h 2/1. That is a relatively common build and there still was nothing "perfect" available for canned maps.
Have you tried going through the dyno seets thread, or sticky to see if you can find a comparable build? If you do, maybe contact whoever posted it and see if they will send you a acopy of the map, assumng all else is the same?
Beyond that, my bag of tricks is empty.
