Ignition coil check out
RE: Ignition coil check out
Pretty much do a continuity test - secondary hot lead to common ground (I believe) and primary to ground. Secondary will have a fairly high resistance, primary will be much lower. Of course, the coil could test good and still be breaking down when functioning - you may have to sub a good one to see. Sorry, electrical problems are a pita.
zoorider
06-22-2006 07:32 PM
