H-D SE Tuner vs V&H FB3
Riding FLHTK 2012
V&H Power Duals, Monster Mufflers, V&H Air Cleaner
Now ready to add Tuner to help with lean running and heat.
Have been told by a few that H-D is better.
I know V&H has improved.
I am not a technical guy or a wrench.
Some good advise would be appreciated.
Thanks
Thanks
I don't know about the SE tuner but I just used a FP3 on my Dyna with slipons and aircleaner and I am very happy. The FP3 is unbelievabley easy to use and takes about 5 min start to finish. The map I used runs great and really cooled my bike down and I haven't even tried the auto tune feature yet. Hope this helps.
I dont have any personal experience with the FP3 but the reports are that it works well. Since you are using V&H parts it should be very easy to get dialed in. The downside, from what I have read, is that the FP3 is mostly a stage 1 tuner. So if you plan on adding cams down the road it might not work out. The SE tuner is very powerful but very complex. Unless you are willing to spend a LOT of time learning how to use it stay away. It is not for beginners. Just my opinion
I don't think the FP3 is compatible with the 2012 touring bikes. You should check the web site. I use the fp3 its a great product. But If I was in your shoes I would now go with the power vision with auto tune. Im not sure about the number.. Any how if you order it from fuel moto . I think if you tell them what you have on you bike, the will preload a map for you and you can just flash your bike . Then if you like you can tweak it with the auto tune. just my 2cts....swifty
Thanks for the replies!
Now I am doing more thinking.
On the one hand I am not likely to do more serious performance work, i.e., cams, bore etc. So a cheaper version (V&H correct item) could be ok. I have changed bikes every 5 years or so as I put on a fair number of KM per year.
The SE is $550 here in Ontario and the V&H is $315.
However the wrench that has always worked on my Harleys says the H-D is the best and my dealer who sells lots of V&H exhausts says they quit offering the V&H a couple of years ago because of so many problems......
I aso had the thought that V&H and V&H would be the best??
I won't be doing any tweaking myself most likely so the complexity of the SE is not a problem as I have very adequate tech to do that for me.
Dang..... seem to be leaning toward spending the extra $200 for the SE and be confident that if I do (at 72) keep this bike as my last, I can do some upgrades with the same module.
Thanks again.
I will post the decision and results when they happen.
Thanks again.
If the new FuelPak 3 will work on your bike and you have a smartphone, go with that. The older model FuelPak they are referring to works good as well, just not nearly as well as the new model.
The SE Tuner is very nice, but you can grenade your engine with it if you don't know what you are doing. If all you are going to do for a while is stage one, get the new FuelPak and ride.
If they don't make the new FuelPak for your model, get the Dynojet Power Vision.
I hear he auto tune on the new FuelPak works fantastic.
You are correct Swifty
My bad. the unit for my scoot is LCD by V&H.
What's the poop on that version?
tbannister
11
10-26-2013 04:23 PM
