Ironhead A place to talk about Ironheads.
78
Old 10-07-2014, 11:17 PM
Wcm71's Avatar
Wcm71
Wcm71 is offline
Default 78
I'm thinking of putting electronic ignition system on by 78 ironhead . Not sure which direction to go or what to get hoping y'all could you help me with some feedback.
Thanks
Old 10-08-2014, 05:43 AM
IronMick's Avatar
IronMick
IronMick is offline
The best is the Ultima ignition kit $154.95 from Jireh Cycles ...
http://www.parts123.com/parts123/yb....Z5Z5Z50000123a
They usually have it on their eBay store altho i do not see it there right now ...
http://stores.ebay.com/Jireh-Cycles?_rdc=1
You do not need the programming kit ...
http://www.ultimaproducts.com/programmableignition.html
Installation is simple, but there are a couple of points where the instruction sheet is not clear, so ask here before you begin ...
http://www.ultimaproducts.com/53-644_Ignition.pdf
Old 10-08-2014, 01:50 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is online now
Received 4,536 Likes on 2,872 Posts
that ignition is all i use in the shop today BUT the coil in the kit is beyond junk use a dyna as a choice it needs to be 3 OHMs - your original coil is 3 OHMs stock but test it with a meter as things have a way of being incorrect when an issue happens
if you had points its a 5 OHMs coil just so you know and you cant use that one
Old 10-08-2014, 03:07 PM
Wcm71's Avatar
Wcm71
Wcm71 is offline
thanks for te info i went to the ebay site Jirch i see i can pick up a wiring harness aswell. I'm hoping to have evrything I need order soon and my baby back on the road
Old 10-08-2014, 09:53 PM
IronMick's Avatar
IronMick
IronMick is offline
I have heard stories about the Ultima ignition coil being unreliable, but that is not my experience. I have seen only one case on the XLForum IronHead forum. Myself and several to many other local guys have been running them for years with no problems.
A few of us locally are running the Jireh kit. The kits on Jireh are older units. They do not have the 3 dead rev's programmed as do the new kits so they fire on the first rev of the engine. This is perfect if you have a kick start.
"They say" that the three dead rev's result in less wear on the starter motor. I think this is not very significant.
rouskie
Ironhead
03-20-2017 10:14 PM
chrisislegend01
Ironhead
02-27-2017 09:04 PM
Wcm71
Ironhead
11-03-2014 04:53 AM
Harbri
Ironhead
03-30-2014 12:24 PM
j88j
02-06-2012 01:43 AM
Quick Reply: 78
