Ironhead A place to talk about Ironheads.
Rocker box gaskets
Old 05-31-2015, 02:34 PM
lownslow's Avatar
lownslow
lownslow is offline
Default Rocker box gaskets
1970 XLH, front rocker box started leaking. Bought some new gaskets off flea bay, sorry, and these are beaded on only one side. Should that side go up facing the cover or down facing the cylinder?
Or, would it be wise to just order James gaskets and shelf these. It's not a huge leak, just seeping pretty good.
Old 05-31-2015, 03:01 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
some have had luck with those and the pinto red goes up -
we use the stock paper - as it is all that was available for many years BUT - we use the glue - called ( the right stuff ) by loc tite - what i do is use gloves put a wad into your fingers then smear on both sides of the gasket completely - having a paper towel handy put the gasket into the center end of the paper towel and fold it over the top - change the gloves - now pat the paper towel flat open remove the gasket, put it in another handy paper towel fold and pat it down < as you put it into the third towel you will see it starts to look like a cometic foam gasket - some times it takes 3 or even 4 times to get the right texture to happen - install and tighten the cover - it will not leak now - and it will take a rubber dead blow hammer to remove the cover in the future -- as it is stuck in place and sealed completely
Old 05-31-2015, 03:18 PM
lownslow's Avatar
lownslow
lownslow is offline
Thanks John. I'll try these and see if it hangs tight. If not I'll use your loctite method. Why not just buy cometic gaskets???? And is there a torque spec for the bolts? I have the original SM and it's not real good IMO.
Old 05-31-2015, 07:05 PM
lownslow's Avatar
lownslow
lownslow is offline
Found the torque spec, 20 ft lbs., looking in the wrong spot. The gaskets that were in there looked pretty pathetic and thin. I'll get some riding time in and see how these hold up.
Old 05-31-2015, 09:43 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
my shop was flooded again 3rd time in a 2 weeks just got back sorry missed your question
NotAknucklehead
Engine Mechanical Topics
05-20-2018 08:46 PM
daven9113
EVO
07-29-2017 01:51 PM
izzyfutch
Ironhead
03-15-2011 09:28 AM
texasridr
EVO
17
06-06-2009 10:20 PM
99FXSTC
EVO
09-21-2007 07:17 PM
Quick Reply: Rocker box gaskets
