Head Gasket Leak?
Old Sep 21, 2007 | 03:48 PM
99FXSTC's Avatar
99FXSTC
6th Gear
Default Head Gasket Leak?
I have a 99 EVO with 10,000 miles and noticed oil/gasseeping out of the front cilinderbetween the cylinder & head.Itappears to be a leak in he gasket. Being new to Harleys I was wondering if thisis common andif I'm doing the job if there is something else I should look for while the heads are off. Thanks
Old Sep 21, 2007 | 04:02 PM
99FXSTC's Avatar
99FXSTC
6th Gear
Default RE: Head Gasket Leak?
Correction. Not to sound like a total idiot. I just ran the bike for about five min. and noticed the leak was comming for the valve cover gasket and not the head gasket. Since it looks like I have to take off the tank to repair it, I was going to replace both front and rear.Any suggestions?
Old Sep 21, 2007 | 04:07 PM
Dr.Hess's Avatar
Dr.Hess
Rocker box gaskets are a pretty common issue. I use the metal ones with the silicone on them. Last ones I did on the Sportster also got a thin coating of NAPA's Aviation Gasket Maker per the recommendation of a local aftermarket shop. Get a genuine HDshop manual. It is a fairly straight forward job. I don't pull the rocker shaft, I just turn the motor so that the valves are both closed and tighten the bottom box down evenly with the shaft in place. You can do what you want, but I find it easier than trying to push the shaft back in against the lifters.
Old Sep 21, 2007 | 07:17 PM
Fishrdr's Avatar
Fishrdr
I'vehad to replace the rearrocker cover gasketsmy 98 dresser twice. You may want to either buythe tool ( rocker box wrench )to get theallen head bolts out or you can cut off an allen wrench. Getting the cover over the 1 push rod can be tricky, but other than that it's pretty straight forward repair.
jambo1989
Nov 20, 2016 09:56 AM
lownslow
Ironhead
May 31, 2015 09:43 PM
rkcmike63
Jan 12, 2014 07:33 PM
texasridr
EVO
17
Jun 6, 2009 10:20 PM
johnny1966
Oil Archive (no new posts)
Nov 8, 2007 04:22 PM
