Head leak?
I discovered really small drops of oil on top of the tranny cover. Upon further looking I found what appears to be the rear cylinder head gasket leaking... I attached a photo. It doesn't seem to be much but not sure what to do. Should I just keep an eye on it or is this a serious problem? Please reply if you know..
Ride safe,
Mike.
Ride safe,
Mike.
looks above the head gasket to the valve cover- so not a crucial area.
check that the breather is not obstructed ( so that pressure does not build up)
to get true source of seep, clean area with carb cleaner ( careful of painted areas). then spray with drugstore foot powder ( 99¢ store)...powder will wash away at source of seep, pinpointing it.
having older bikes, I have some with seeps for 20 years...no big deal - however the head gasket IS a big deal, but I don't think that's your problem.
Mike
Mike
I agree on a rocker box gasket leak. The 2 Harley's I've owned before I bought my new one both developed a leak there. The first one (sportster) I replaced the gaskets myself (not that big of a job). The second one (fatboy) I just kept an eye on it for a few years. Never got worse. Ended up trading it in on my new one.
looks like rocker box gasket .Clean it with. engine or brakes cleaner . then ride for a bit and check . if its rocker box , you can either re torx it or replaced the gasket . .As i about to replace mine i kinda noticed ,one bolt on the back side is loose . I retorque it .no leak so far 20k + miles.
Ride safe,
Mike
