Blown head gasket.
Old Nov 4, 2012 | 06:25 PM
Shackleford's Avatar
Shackleford
Default Blown head gasket.
Hello again.
I have a head gasket on the rear cylinder that has gone bad and needs to be replaced. I've never been into the top part of the engine, but I have my factory manual, and I'm fairly confident in my mechanical abilities, so I think I will probably be alright there.
I plan on fixing it as soon as I can, but will it be alright driving it until I can get the new parts? I have been keeping a very close eye on the oil level. I'm just not quite sure how serious this problem really is besides leaking oil all over the place. Also, it's not leaking terribly fast, but it is leaking none-the-less. Any advice you guys can give me would be much appreciated, thank you.
Old Nov 4, 2012 | 06:32 PM
Sportabagger's Avatar
Sportabagger
Are u sure its the head gasket and not a rocker box gasket.
Old Nov 4, 2012 | 06:44 PM
wanabe's Avatar
wanabe
either gasket is no big deal... as long as its just a small amount of oil that you see-
the fix isnt hard either- have to admit that i have never done it, but i have had guys tell me the "how to" several times (cause i have blown mine twice now- in fact, i have been riding the past 500 miles or so with a gasket leak)...
my first gasket was a head gasket. the second one was a rocker gasket.
i think its a disadvantage of efi. we never know when our bikes are really warmed up so i know i get on it too soon. but, hey its just too much fun!!
Old Nov 5, 2012 | 12:29 AM
dwagar's Avatar
dwagar
If it's blown through to the cylinder I wouldn't ride it. If its just an oil leak, then it's just messy.
I changed mine this spring, I had annoying oil leaks on both. Not a hard job, just follow the manual.
Make sure you have the right tools, the 12 pt socket for the head bolts was one I had to search a couple of stores for.
Use good gaskets.
Old Nov 5, 2012 | 01:03 AM
DOMAPOI's Avatar
DOMAPOI
My rocker box gasket on the rear started leaking after I changed oil the last time. Leaked for about two runs but was minor. Then it stopped leaking. Oil lever is steady and even when it leaked was so minor the level never changed. Won't do anything to mine unless it starts leaking again and only if it is bad.
Bluesrider.df
Engine Mechanical Topics
Aug 30, 2016 10:44 PM
mad jak
Jan 7, 2015 12:47 AM
Stick655
Exhaust System Topics
Jun 29, 2013 11:22 AM
HDSmurph
Ironhead
Jan 20, 2011 09:27 PM
johnny1966
Oil Archive (no new posts)
Nov 8, 2007 04:22 PM
