Quick rocker box gasket leak fix
Old Jul 12, 2016 | 11:38 AM
daven9113's Avatar
daven9113
Default Quick rocker box gasket leak fix
These Evos are pretty dependable bikes, but with age and mileage things need to get addressed. About 40K miles ago, I did a base gasket change and most gaskets are still holding up. The lower rocker box gasket on the rear cylinder began to weep, then leaked several months ago. Finally, I decided to take care of it. Parts are still readily available at the dealership. All four gaskets were under $20, and it took an hour to complete the job.
Some important notes:
1. make sure the cylinder you are working on is on TDC
2. rear top rocker cover on some bikes will need an Allen key shaved down a bit to get between it and the frame
3. torque sequences and spec are crucial so not to warp the rocker box, because they are prone to warp
4. the top cover rubber gasket from H-D was still a tad off, but it's workable, if you ensure the lower side is on right. A little off on front higher side is OK, when torqued down. Maybe other gasket makers are better.
Keep those Evos on the road...and safe riding!
Attached Thumbnails Quick rocker box gasket leak fix-slide1-1-.jpg   Quick rocker box gasket leak fix-slide2-1-.jpg   Quick rocker box gasket leak fix-slide3-1-.jpg
Old Jul 29, 2017 | 12:36 PM
Mac Kanick's Avatar
Mac Kanick
Stage I
What are torque specs please ?
Old Jul 29, 2017 | 01:51 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Depends on which bolt you are talking about.
The 1/4-20 have a lower torque than the 5/16-18 bolts.
I don't remember off the top of my head but that information is readily available in your factory service manual.
If you don't have one and plan on working on your bike yourself then you need to get one.
Eagle15
Dec 15, 2017 09:07 PM
jlasoftail
Jan 4, 2014 10:35 AM
flat4fan
Aug 23, 2012 08:45 PM
biodog77
Mar 21, 2011 06:10 AM
texasridr
EVO
17
Jun 6, 2009 10:20 PM
