Ironhead A place to talk about Ironheads.
do i NEED a battery for XLCH?
Old 11-27-2006, 07:14 PM
Wis 74 XLCH's Avatar
Wis 74 XLCH
Wis 74 XLCH is offline
Stage II
Default do i NEED a battery for XLCH?
Do i NEED a good battery for running my 74 XLCH? Since it doesnt have electric start (kick start only)and produces its own power for lights when it is running why is a battery needed? I picked this up on ebay for a winter project ($1450) and have been buying little things for the last month.
Scott
Old 11-27-2006, 08:57 PM
piniongear's Avatar
piniongear
piniongear is offline
Default RE: do i NEED a battery for XLCH?
Yes, you certainly do need a battery to run your kick start Sportster. The main reason is because the bike uses an electric ignition that requires 12v power. As a practical matter it also needs a battery to power the head/tail lights.
The generator produces 12 volts, but your lights will dim at a red light, so get a battery. You will need it if you plan to start the engine up........pg
Old 11-28-2006, 08:00 AM
Ladyhawke's Avatar
Ladyhawke
Ladyhawke is offline
I have owned a couple sportscars powered with generaters. When the generater went out, the battery fired the plugs and I got home. Easier to ride than push.Good luck with it...
Old 11-30-2006, 04:45 PM
mhardy's Avatar
mhardy
mhardy is offline
5th Gear
generator FTW
Old 11-30-2006, 04:47 PM
Rhubarb's Avatar
Rhubarb
Rhubarb is offline
Couldn't you put in a magneto and be rid of the batter?
Old 11-30-2006, 09:02 PM
pococj's Avatar
pococj
pococj is offline
Received 1,211 Likes on 461 Posts
You can put the magneto in, but it's expensive, and since it is usually driven off the tach drive on this model, some have had problems.
Try this as an experiment - disconnect the battery, and have at it. If you get it started, it won't run worth a crap at idle and some above. The generator doesn't put out enough juice at those low rpms.
dinolo24
11-14-2014 09:53 AM
nighty0619
04-06-2014 12:25 PM
TexSport2013
01-23-2014 04:47 AM
blueangel73
08-07-2013 09:52 PM
Nickpisp
04-11-2009 08:13 PM
Quick Reply: do i NEED a battery for XLCH?
