Help bike won't start
Old Apr 6, 2014 | 10:19 AM
nighty0619's Avatar
nighty0619
Default Help bike won't start
So I went for a ride yesterday and bike was working fine. I installed a new air intake last night. I go to start it this morning and it tries to turn over like 2 times real slowly and won't start up. Any suggestions? I can't imagine it has anything to do with the air intake?? All the lights come on so I don't think it's the battery...
Old Apr 6, 2014 | 10:32 AM
cHarley's Avatar
cHarley
Sure sounds like a bad battery, it takes a lot more battery power to crank the motor over than it does to run the lights.
Do the lights dim when you hit the Start button?
Are you still using the original (6+ year old) battery?
Old Apr 6, 2014 | 10:39 AM
nighty0619's Avatar
nighty0619
Yes lights dim. Maybe it is the battery. I'm not sure if it's the original one. My guess is that it is. I just bought the bike last year with <1000 miles on it so I doubt it was changed
Old Apr 6, 2014 | 10:57 AM
cHarley's Avatar
cHarley
If you have a digital volt meter you can measure the battery voltage, it should be 12.7 - 12.8 volts if it's fully charged and shouldn't drop below 11 volts when you press the Start button. But I'm betting that would just be an exercise and that you need a new battery.
Old Apr 6, 2014 | 11:02 AM
nighty0619's Avatar
nighty0619
Already on my way to the store! Hopefully they have one in stock. It's a nice day out and I've been itching to ride all week
Ployd4's Avatar
Ployd4
How long of a ride? If it was a short ride then the battery didn't have time to charge. If it was a long ride couple hours than there might be another problem. I doubt it has anything to do with the work you performed. But charley is right a meter is your friend.
Old Apr 6, 2014 | 12:19 PM
nighty0619's Avatar
nighty0619
Yep battery was dead. New one did the trick. Might be a dumb question, but on the new battery the terminal screws go in vertically, and on my old one they were horizontal. This makes the ground and power wire stick out and it's making it very difficult to get the battery all the way in. Should I just bend the power/ground cable connectors to make it all fit? Or is there an adaptor I can get to change the battery terminal orientation?
Old Apr 6, 2014 | 12:24 PM
cHarley's Avatar
cHarley
I would take it back and get the correct battery for your bike. Where did the battery come from and is it specifically listed as fitting your year/model bike? The cables aren't intended to be mounted to the top of the posts.
Old Apr 6, 2014 | 12:25 PM
Alpha Mike's Avatar
Alpha Mike
Often times the batter will come with adapters for vertical or horizontal attachment. if your did not the store likely has them
John LaRoe
Shovelhead
Sep 15, 2016 12:55 PM
bocody
Mar 9, 2015 09:43 AM
draggingframe13
EVO
11
May 30, 2013 09:43 PM
PanGuy
Panhead
May 4, 2013 10:29 AM
lovethemhogs
Ironhead
Sep 17, 2008 11:42 PM
