simple wire digram for minimal components
12-29-2012, 04:01 PM
Anyone provide a simple wiring diagram for a system with bare minimum components? Basically be like fuse box, turn signals (optional), head/tail light, ign switch, Batt, regulator, generator, Speedo/tach light. Thanks
12-29-2012, 06:46 PM
The part labelled cyl is actually the solenoid.
There needs to be a relay between the IG ignition switch terminal and the start button.
It is essential the both wires coming off the battery + pass thru a 30 amp circuit breaker.
12-29-2012, 07:59 PM
Also curious how big a pain it would be to install a neutral indication pilot light? Can always count on you Mick! Thanks bud and happy holidays!
Reason: Forgetfulness
12-29-2012, 08:01 PM
Also should mention its for a xlch kicker only. Guess it don't make a difference other than not needing to wire a starter switch?
12-29-2012, 08:03 PM
12-29-2012, 08:08 PM
Thats what I figured.. What about a 5th gear? That would be sweet
12-30-2012, 06:29 AM
No possibility of 5th gear either. Also, [? i have heard that] 4th IronHead has the same ratio as 5th Evo so it does not make a difference at cruising speed.
CaptainCalf
01-08-2024 12:05 PM
Blk80bike
Electrical/Lighting/Alarm
09-25-2016 08:09 AM
superjesse
General Topics/Tech Tips
02-24-2015 02:32 PM
Ironhead123
Ironhead
14
06-23-2012 06:43 AM
hjc950
Ironhead
17
09-06-2011 07:00 AM
