Need help adjusting carbs on 79 Ironhead
you did not explain what its doing / and most iron head issues with running turns out to be the intake leaking vacuum --
if it wont idle so as you can turn the mix screw and the engine responds than ------
i would start with the intake manifold re new all o rings or flat rings and gaskets with that done / start over and see what happens -- jz
It's spitting and sputtering at low speeds. The pilot screw was turned out about 20 turns instead of the recommended 1/2 to 1 1/4 turns. I followed someone else's suggestion of seating it gently then turning out 1 1/4, but couldn't even get it to start. I went back to where the pilot screw was placed originally (just bought this beast a few days ago) and tightened it until it stalled, then turned it back out 1 1/4 again. It's better, but not great. I'm wondering if something else is off and that's why the pilot screw needs to be so far out?
Thanks for the reply
usually that is caused by a dirty idle port. the idle port is really small, and hard to get clean if your not sure what you are doing and the very first part that gets clogged.. you need to run a tiny wire through the smallest ports.spray carb cleaner through the ports and watch for it to come out the other side. a lot of the ports go two or three directions, you need to plug the extra passages with your finger and make sure the entire port is flowing rite. there is a lot of things that can cause problems, wrong jets,worn leaking butterflys, air leaks.. i have even seen people drill jets and passages out thinking they are making it flow better. unless you know exactly what your doing, drilling only turns a carb into a paperweight. you can have the right jet number, but its actually drilled 20 sizes bigger. the first thing to do is thoroughly reclean it and go from there.
Thanks! Will try again tomorrow. The FM says the pilot screw should have a washer and O ring as well. Mine does not. I used a pipe cleaner to check-nothing came out. Maybe that's part of the problem as well. I just figured out that my voltage regulator isn't working too. Looks like I have some work ahead of me before I jump on and go :/
Bendix carb help ...
Rebuilded Bendix - now it's flooding..
http://xlforum.net/vbportal/forums/s...d.php?t=941501
ReBuilding the Bendix Carb
Bendix Carb
http://xlforum.net/vbportal/forums/s...d.php?t=596371
Setting the Bendix
http://xlforum.net/vbportal/forums/s....php?t=1294700
Bendix Carb
Setting the Bendix
