oil pressure/genorator indicator dash lights
Yes and yes.
The oil light has a single wire that runs from the pump up to the bulb on one side, and a 12 volt source for the other side.
The gen light has a single wire that runs from the A terminal of the gen up to the bulb on one side, and a 12 volt source on the other.
You can use the same 12 volt wire for both, with a Y-connector.
Stock wire colors are orange for the 12 volt, tan for the gen lite, green for the oil light.
