Motorcycle Audio-Buy/Sell/Trade Motorcycle audio Want to Buy (WTB), For Sale (FS), and Trade.
Mark this thread as Unsold
FS: Power Acoustik RZ4-2000D Amp
Old 02-23-2017, 08:51 PM
Autotec's Avatar
Autotec
Autotec is offline
Default Power Acoustik RZ4-2000D Amp
Used one season up here in WI. Since my HK head unit decided to stop producing any output, I'm going to go a different direction with the system. It drove my Biketronics speakers great (7.1 front, 6.5 rear, 06 Ultra) Will come with custom bracket to mount the amp above the radio.
I tested the amp with a AUX plugged into my phone with low level outputs before I removed it, and all 4 channels functioned as they should It will come with the high level connectors, cut shorter since that's what I used, to hook up to the factory radio. I did not check the high levels, but since the HU failed, I doubt there is a problem. BTW, it doesn't come with the end caps since they had to be removed for the install.
$75.00 shipped. Take a look at the pictures and let me know what you think.
Old 02-23-2017, 09:02 PM
Autotec's Avatar
Autotec
Autotec is offline
Picture 1, if it works.
Old 02-23-2017, 09:05 PM
Autotec's Avatar
Autotec
Autotec is offline
Pictures 2
Attached Thumbnails Power Acoustik RZ4-2000D Amp-amp-4.jpg   Power Acoustik RZ4-2000D Amp-amp-5.jpg
Old 02-23-2017, 09:11 PM
Autotec's Avatar
Autotec
Autotec is offline
The installed bracket. Not sure if anyone can use it, but it kept the amp secured.
Attached Thumbnails Power Acoustik RZ4-2000D Amp-amp-install.jpg   Power Acoustik RZ4-2000D Amp-bracket.jpg
Old 02-23-2017, 09:37 PM
badazzpred's Avatar
badazzpred
badazzpred is offline
What amp and aftermarket head unit are you going with if you dont mind me asking?
Old 02-23-2017, 10:04 PM
Autotec's Avatar
Autotec
Autotec is offline
After ALOT of research, I decided on the Aquatic MP-5UBT-HS and the Biketronics tried and true BT-4180. I ride every day I can, and I like my music. This mix seems to be the best combination I can come up with.
I was going to keep the PA amp, but since the radio is a touch smaller, the bracket would have to be remade. Figured I would try something new.
I'll lose the CB and intercom, but I've never used those anyway.
Old 02-23-2017, 10:20 PM
Autotec's Avatar
Autotec
Autotec is offline
Plus since I ran the PA with no crossover active, with the gains set about 50% up, I wouldn't miss the gain adjustment with the BT amp.
As we all know, sound quality goes away with our bikes once we hit 60 mph. The only thing we can hope for is volume, and this amp has plenty to offer.
Just trying to help someone here with a upgrade.
Old 02-28-2017, 12:47 PM
Makdaddy's Avatar
Makdaddy
Makdaddy is offline
Ill Take it
Old 02-28-2017, 05:33 PM
Autotec's Avatar
Autotec
Autotec is offline
Originally Posted by Makdaddy
Ill Take it
PM sent.
varnold
Audio Systems
09-02-2015 08:13 PM
just plain john
Audio Systems
04-20-2013 02:43 AM
Harleypingman
Audio Systems
18
10-07-2011 01:24 PM
joe mayo
Audio Systems
03-02-2011 07:00 AM
joe mayo
02-21-2011 01:21 PM
Quick Reply: FS: Power Acoustik RZ4-2000D Amp
