Multi-Fit Parts and Accessories For those Parts and Accessories that fit more than one model of Harley Davidson.
**SOLD**Big Twin HD Stage 2 Big Bore 103 Kit Se-255 cams - $600 obo
Old 12-10-2012, 04:24 PM
metalb00's Avatar
metalb00
metalb00 is offline
Default **SOLD**Big Twin HD Stage 2 Big Bore 103 Kit Se-255 cams - $600 obo
Manufacturer Part Number: 29893-07 Black w/Highlighted Fins
Selling here a NEW Stage 2 Big Bore kit for 2007 and newer Twin Cam Engines.
It has Black Highlighted Cylinders.
This complete kit costs $899 from H-D.
This big bore kit will make a 96" Twin Cam a 103" Twin Cam.
The Stage II Big Bore Kit provides the parts you need to increase the horsepower of your EFI-equipped model. The 50-state street legal kit increases the displacement of your Twin Cam-equipped model from 96 cubic inches (1584cc) to 103 cubic inches (1690cc). Includes Stage II (SE-255) cams, Big Bore cylinders, Big Bore flat top pistons, clips, and a Stage I Air Cleaner Kit with one-piece back plate, integral breathers, all mounting hardware, and gaskets. Also includes a high performance clutch spring. Separate purchase of cam spacers is required. See manual for proper procedure and cam spacer part numbers. Requires separate purchase of primary cover gasket. Not all components shown. 49-state kits include catalyst mufflers or headers, and California kits are street legal on California pollution controlled vehicles when used with Original Equipment mufflers. All EFI-equipped models require ECM calibration* (priced separately).
I'm Pretty sure the kit also fits 88ci and brings it to 95 ci
I am selling this for 600 obo i can be reached at 908-378-0312 after 4 pm most days is there are any questions it is located in union nj and id prefer not to ship
Old 12-10-2012, 04:28 PM
metalb00's Avatar
metalb00
metalb00 is offline
**SOLD**Big Twin HD Stage 2 Big Bore 103 Kit Se-255 cams - 0 obo-3k43jb3hd5e85fb5h3ccaee5fb6766cff1c65.jpg
**SOLD**Big Twin HD Stage 2 Big Bore 103 Kit Se-255 cams - 0 obo-3g83ia3h45ne5g85mbcca64f9506d07f2176c.jpg
**SOLD**Big Twin HD Stage 2 Big Bore 103 Kit Se-255 cams - 0 obo-3e83n23n85n55id5f9cca9dfe9daf4ccc1c1e.jpg
Old 12-11-2012, 06:32 PM
bolt54's Avatar
bolt54
bolt54 is offline
doing some research on this, very interesting opportunity
Old 12-12-2012, 07:14 AM
CndUltra95's Avatar
CndUltra95
CndUltra95 is offline
It is a very good opportunity.
When you consider the parts included.
As for the 88 to 95, the pistons and cams would not be used as the pistons (103's) are larger , not sure if cams would work in a 95inch motor.
Rob
Old 12-13-2012, 08:39 PM
bolt54's Avatar
bolt54
bolt54 is offline
would love to go up to 103" this winter, almost time to put bike away anyway
Old 12-13-2012, 11:46 PM
uscanuck's Avatar
uscanuck
uscanuck is offline
Rob
I don't know for sure but i thought the only difference between an 88/96 and 95/103 was the stroke?
If so, then only the cams would not be used.
Old 12-15-2012, 02:37 PM
bolt54's Avatar
bolt54
bolt54 is offline
gonna do this on my bike at some point, already did cams so this kit would have parts i don't really need, $600 a bit high for me, at $450 or so i would be right there...
Old 12-17-2012, 11:35 PM
peerm13's Avatar
peerm13
peerm13 is offline
Do the heads have the automatic compression releases?
Old 01-29-2013, 03:33 PM
Srrmc's Avatar
Srrmc
Srrmc is offline
Did you ever sell this?
caulk04
03-04-2017 02:20 PM
Paul32730
03-27-2011 03:45 AM
sp9997
10-03-2010 04:39 PM
Quick Reply: **SOLD**Big Twin HD Stage 2 Big Bore 103 Kit Se-255 cams - $600 obo
