2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Manual method to turn on radiator fans
Old 04-14-2015, 08:17 PM
Iwanna's Avatar
Iwanna
Iwanna is offline
Default Manual method to turn on radiator fans
I have a 2015 Limited and have been told that there is a manual way to get the radiator fans to kick on. I can not find it in the owners manual.
I would appreciate any input, besides over heating the motor.
Old 04-14-2015, 08:29 PM
Hammz's Avatar
Hammz
Hammz is offline
No way to do it when the engine is running. When the engine is shut off, they can be toggled on in the first few seconds using the throttle.
Old 04-15-2015, 06:21 AM
Cobra1's Avatar
Cobra1
Cobra1 is offline
Received 1,289 Likes on 523 Posts
Turn ignition to on, do not start engine. Twist throttle to full on and hold. Fans and pump will start and run continuously until ignition is turned off. This is how you bleed air out of the coolant system when changing coolant. Enjoy
Old 04-15-2015, 06:25 AM
Cummins man's Avatar
Cummins man
Cummins man is offline
Shut the bike down with the kill switch, leave the ignition switch on and twist the throttle about half way. It works on the 14. Hope that helps.
cwickgo9 (08-14-2017)
Old 04-15-2015, 07:37 AM
MikeyTX's Avatar
MikeyTX
MikeyTX is offline
??? My fans kick on by themselves when needed. Any number of times they have kicked on moments after I've shut the bike off.
Old 04-15-2015, 11:23 AM
Kevinch's Avatar
Kevinch
Kevinch is offline
..my HDForums tutorial for the day....!!
Old 05-24-2015, 03:16 PM
seabee_biker's Avatar
seabee_biker
seabee_biker is offline
Will this feature only work after the bike has been running? For example, should this work if the bike is cool, sitting in my garage? I only ask because it doesn't work for me this way. I can't find this in my service manual either, but I will keep looking.
Old 05-24-2015, 04:38 PM
Brewmany's Avatar
Brewmany
Brewmany is offline
You should be able to power up the fans and water pump when the bike is cool and has been sitting around by following the process already mentioned. If you can't, then either you're not doing it correctly or something isn't working, which should be covered by your warranty. I don't have my service manual handy, but I recall reading how to activate the fans and pump to bleed the system somewhere in that manual.
Old 05-24-2015, 04:46 PM
Punjabi Rider's Avatar
Punjabi Rider
Punjabi Rider is offline
That is how you purge the cooling system if fluid is added due to no fluid in the reservoir, whenever fans turn on the electric pump also starts cycling the fluid.
Old 05-24-2015, 07:25 PM
seabee_biker
There must be something wrong then. I've done this several times before with no issues. the bike was hot though, that's why I wondered if it has to happen right after shut off. Now I'm wondering if the flash from my Power Vision did something because after I flashed the ecm my EITMS was disabled too. I checked the cooling system fuse and it's fine. Everything else that's common sense to me seems good. Guess I'm making a trip to the dealer.
Quick Reply: Manual method to turn on radiator fans
