Torque specs front wheel needed
Here is what I have for 2014 Touring bikes. s/b the same for 2015
FASTENER TORQUE VALUE
Brake disc, front, screws 16-24 ft-lbs 21.7-32.5 Nm
Front axle nut 70-75 ft-lbs
Front axle pinch screw 18-22 ft-lbs 24.4-29.8 Nm
Brake caliper, front, mounting screws 28-38 ft-lbs 37.9-51.5 Nm
Banjo bleeder bolt to front caliper 17-19 ft-lbs 23.1-25.8 Nm
This is truly a hellofa forum, where else could you get that info, that quick, the other day i was looking for Cummings engine valve lash specs and it took awhile here on the interweb. And several places wanted money for the info, I try to not take this forum for granted although Paul Blart screws things up sometimes.
I agree! I have received great support from the forum over the years. I just moved up from an 08 SG to a 15 SGS on Friday and appreciate the quick support.
I had a new enforcer wheel power coated partially black, basically making the black parts that were already black on the enforcer wheel a gloss black to make the black stand out with metal contrasts. I had to put it on. Not a huge difference but a subtle change.
The little square box with the Mountains init is the quickest and easiest way to post a pic iv found, just found thatout recently!
