Get noticed! New Side Marker Lights as turn indicators???)
Getting the parts together to smoke out the azz end of my limited. As I'm adding the plasma rods to mine, I was browsing through the install threads on the rods and many have said they liked the new rear brake/turn signals that go on the back of the saddlebags more for others being able to see when you're planning on making a turn more than any other reason. I personally don't like the look of them at all and looking at the new 14' parts the thought occurred to me...how about making the new saddlebag side marker lights into running and turn indicators? Me thinks it would be relatively easy to do, you'd just have to modify the wiring harness and connect to the bikes turn signal wiring under the seat no? Anyone else wanna chime in on this? I'm considering being the guinea pig on this one...
Link for reference:
http://www.harley-davidson.com/store...11-68000083--1
Link for reference:
I don't think those modules work with the canbus on the new bikes. I think you would either have turn/ brake or running. But I've been known to be wrong before.
Custom Dynamics TFC3 Dual Converter (about $5) per side will do the trick nicely...see item 6 on these instructions for the Plasma Rods Installation:
http://www.customdynamics.com/instru...sma%20Rods.pdf
edit: Monty...if you notice the Posi-Tap connectors mentioned in the instructions...OMG...they are the sh*t!... Be a good thing to pass on to all of your audio buds...
http://www.posi-lock.com/posiplug.html
Custom Dynamics TFC3 Dual Converter (about $5) per side will do the trick nicely...see item 6 on these instructions for the Plasma Rods Installation: http://www.customdynamics.com/instru...sma%20Rods.pdf edit: Monty...if you notice the Posi-Tap connectors mentioned in the instructions...OMG...they are the sh*t!... Be a good thing to pass on to all of your audio buds...
