Oil Archive (no new posts) An archive of oil related questions and comments.
Mobil 1 15-50 vs Mobil 1 V-Twin 20-50
Old 08-14-2016, 09:53 PM
No U Glider's Avatar
No U Glider
No U Glider is offline
Default Mobil 1 15-50 vs Mobil 1 V-Twin 20-50
My indie suggested I run Mobil 1 15-50 rather than buck up for the V-Twin 20-50. Bike is near new and I don't want to cause problems over a couple $.
Thoughts?
Old 08-15-2016, 12:39 AM
mglax13's Avatar
mglax13
mglax13 is offline
A zillion posts on this. It's fine. Run the 15W-50 and save yourself the cash. Works just fine.
Now run before the oil snobs come around...
The following 3 users liked this post by mglax13:
OldDrummer55 (03-30-2020), rocket23 (03-30-2020), SIDECAR BOB (08-16-2016)
Old 08-15-2016, 09:12 AM
Qdog002's Avatar
Qdog002
Qdog002 is offline
You don`t need motorcycle specific oil because the motor and clutch use separate oils. Using the 15w-50 is fine.
The following 2 users liked this post by Qdog002:
Old 08-16-2016, 12:18 AM
Crazy's Avatar
Crazy
Crazy is offline
Received 1,541 Likes on 810 Posts
Another vote for the 15w50 here.
Old 08-16-2016, 07:16 AM
nvsteve's Avatar
nvsteve
nvsteve is offline
Been using 15-50 for about 5 years or more. It's fine.
Not recommended for primary.
Old 08-16-2016, 07:26 PM
Crazy's Avatar
Crazy
Crazy is offline
Yep, I should have mentioned that. I use 15w50 in crankcase only. Mobil-1 20w50 in the primary.
Old 08-17-2016, 10:19 AM
troop's Avatar
troop
troop is offline
Why waste high $$ synthetic in the primary? Any cheap diesel/20w50 will work fine there..
Attached Thumbnails Mobil 1  15-50 vs Mobil 1 V-Twin 20-50-12945906-0161-491c-8b71-d89b7a7f8fe5_1.5a993d02a62f0dac68a98e09d8712af7.jpeg
Old 08-29-2016, 06:02 PM
kink04fxd's Avatar
kink04fxd
kink04fxd is offline
15-50 works fine in the primary. Been running it for years. Prob overkill
Old 09-02-2016, 08:34 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
What we see above is the usual response to an oil query! I'm quite happy using Mobil V 20-50 and don't see the small difference in price to be worth worrying about.
Old 09-02-2016, 09:34 AM
Ridewright Wheels's Avatar
Ridewright Wheels
Ridewright Wheels is offline
Former Sponsor
Cycle oils tend to differ from automobile oils in the anti-wear additives. API SM oils tend to be very low in sulphated ash, phosphorus and zinc (aka low SAPS).. Racing oils, motorcycle oils and aviation oils tend to be higher SAPS content, specifically ZDDP, which many associate with less wear.
Acceptable alternates are ACEA rated oils with an ACEA A1 or A3 approval.
Quick Reply: Mobil 1 15-50 vs Mobil 1 V-Twin 20-50
