Oil Archive (no new posts) An archive of oil related questions and comments.
Location of Oil Drain Plug 2011 FXDWG
Old 10-31-2010, 12:50 PM
F0xtr0t's Avatar
F0xtr0t
F0xtr0t is offline
Default Location of Oil Drain Plug 2011 FXDWG
I just broke in my FXDWG I want to change the oil. I can't find the right plug. I don't want to drain the tranny just yet and I don't want to crack the cases. So where exactly is the drain plug on the 2011? Also I can't find a service manual for it yet.
Old 10-31-2010, 01:02 PM
perki48's Avatar
perki48
perki48 is offline
Received 4,100 Likes on 1,913 Posts
Its on the left side rear of your oil pan under the transmission. Its the plug on the side. The one on the bottom is the trans.
Old 10-31-2010, 01:32 PM
skidder's Avatar
skidder
skidder is offline
It may be hard to see because of the rubber bumpers on the underside of the frame. It's there and it's not facing down rather sideways instead, the only drain plug that is not pointing down. It's the same size as the other 2 drains which face down of course.
Old 10-31-2010, 05:35 PM
F0xtr0t's Avatar
F0xtr0t
F0xtr0t is offline
Is it facing primary side or exhaust side? Does it have an Allen hole in the middle?
Old 10-31-2010, 06:26 PM
skidder's Avatar
skidder
skidder is offline
Primary side. If you see the hole I think you see....that's not an allen key hole.
You found the drain plug for motor oil. 7/8's I think.
Old 10-31-2010, 09:45 PM
lo-rider's Avatar
lo-rider
lo-rider is offline
Default read your owners manual
Your owners manual tells you all this.
Old 11-01-2010, 08:50 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
+1 if you didn't get one go back to your dealer and make them give you one.
Old 11-01-2010, 02:39 PM
F0xtr0t's Avatar
F0xtr0t
F0xtr0t is offline
I never checked the manual. With the big push for dealership service only and no more DIY I didn't think that there would be any useful information in there beside how to work the computer. I guess I should .
Old 11-01-2010, 07:28 PM
Potato_Potato's Avatar
Potato_Potato
Potato_Potato is offline
Old 11-01-2010, 08:42 PM
skidder's Avatar
skidder
skidder is offline
That picture ain't what's under a Dyna.
Quick Reply: Location of Oil Drain Plug 2011 FXDWG
