84 Classic with enclosed chain
01-30-2011, 04:22 PM
I have a 84 FLHTC Classic with a enclosed chain drive. I have to check my manual but what weight oil is recommended
01-30-2011, 07:29 PM
anything will work. what ever you have around the garage is fine.
02-18-2011, 04:54 PM
In the manual for mine it says engine oil.
03-28-2011, 03:29 PM
I hadda 84 FLTC with enclosed chain , seems around six ounces of motor oil IIRC ..
Loved it better than the belt drive myself
03-28-2011, 06:35 PM
Best system Harley ever had.Not sure about your's but my fxrt only took 3 1/2 qts. to change oil,used the rest to do the chain. Traded it with 112,000,adjusted the chain twice.
04-03-2011, 05:15 AM
FLTC took four quarts motor oil ..
Biggest problem I had with enclosed chain , was the chain case seals would leak if ya torqued the axle to tight after a tire change ..
Bought new and traded in 1988 on a 1988 FLTC , had 242k and some change on it ..
kino44
EVO
07-15-2014 07:06 PM
Khshockey44
07-15-2011 08:20 AM
71Ironman
Oil Archive (no new posts)
05-15-2010 11:48 PM
Ragin_Republican
22
02-02-2007 07:31 PM
tony
Classic
06-17-2005 01:21 AM
chain ,
change ,
checking ,
davidson ,
drive ,
enclosed ,
flht ,
fluid ,
harley ,
harlry ,
hartlay ,
inclosed ,
oil ,
rear ,
tire
