Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
1984 Enclosed Drive Chain
Old Jul 12, 2011 | 04:20 PM
Khshockey44's Avatar
Khshockey44
Default 1984 Enclosed Drive Chain
Does anyone know much about these drive chains?
Old Jul 12, 2011 | 08:48 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Yes, some people know about these drive chains...
Old Jul 12, 2011 | 10:24 PM
Khshockey44
Do you know where I can find some literature on this subject... I have searched and shearched and cannot seem to find much on this subject.
Old Jul 13, 2011 | 01:05 AM
j1mmy's Avatar
j1mmy
a service manual will talk about it some.. pinwal cycle on ebay has 2 setups for sale. it was an over engineered bad idea,an open chain worked fine for a long time and still does.the thought was to stop the chain from throwing oil everywhere,it didn't work,that is why harleys use belts now
Old Jul 13, 2011 | 04:37 AM
Khshockey44
Yea it trips oil all over the place... And supposedly a pain to take the rear wheel off... I'm looking to do away with the enclosure and just run an open chain on the bike but I jace heard it oils the chain through the primary and then I have heard that it doesn't so I'm not sure... And I don't want to experiment and find out it really does ya know?
Old Jul 13, 2011 | 01:56 PM
nomad billy's Avatar
nomad billy
It has nothing to do with the primary,it's self contained.It was a good idea kept the chain clean and lubed,made the chain last a lot longer.Take the screws out put some silicone sealer on the aluminum primary and tighten it back up,it's usually the bottom piece.The trick is not to tighten it much.Take it off if you want and,sell it,some still see the benefit.
Old Jul 13, 2011 | 02:26 PM
Khshockey44
Thanks for the info... Do you know what it would take to convert it to a belt drive?
Old Jul 13, 2011 | 03:29 PM
j1mmy's Avatar
j1mmy
i read the inner primary and rear wheel is a little different.i bet you could just bolt a newer primary,belt setup, and rear wheel on.i just saw a page for a company that sells a belt conversion,you have to grind the transmission and inner primary to make room for the front pulley.it looked just like a current flht..i would just take the covers off and run an open chain..
Old Jul 13, 2011 | 05:06 PM
Khshockey44
Where did you find that company? I was thinkin about taking the chain covers off and running a new back wheel but wasn't sure how much work that would consist of
Old Jul 15, 2011 | 02:23 AM
j1mmy's Avatar
j1mmy
i typed harley or flht? enclosed chain conversion on google,it was just a random site..the chain tins look pretty easy to remove,then it would be the same open chain hd used for 70 years prior
