Oil Archive (no new posts) An archive of oil related questions and comments.
oil drain plug location on 85 flht
Old 08-05-2012, 05:02 PM
lebert's Avatar
lebert
lebert is offline
Default oil drain plug location on 85 flht
Where is the drain plug for the oil on a 85 flht. The bike has been sitting for a while and all the oil is down in the crankcase im told and when i turn it over it pukes out the breather. Would like to drain it and refill with fresh.
Old 08-05-2012, 07:48 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
You probably won`t get much out of the tank, you should go ahead and scavenge the oil out of the crankcases first.
Make sure there is some oil in the tank, there doesn`t need to be much in there, just make sure the tank doesn`t run dry.
If the breather hose is still connected to the carb backing plate, disconnect it and point it down to a drain pan and start the engine.
Once you run the engine for a few minutes you should have the crankcases scavenged, some of it will have returned to the oil tank, and some will be in the drain pan.
Now you can drain the tank and put in fresh oil, but don`t put in the full amount, leave about a quart low, just in case there is still some in the crankcase...take it out for a ride and get it up to operating temp, then check the oil again.
The drain plug is on the bottom of the oil tank, on the right side of the bike.
Old 08-14-2012, 05:13 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
There's no drain plug in the crankcase, hence Dan's suggested way of clearing it.
splittie65
EVO
23
08-21-2018 09:41 AM
Passing Lane
10-18-2016 09:35 AM
PORKCHOP
01-11-2010 05:42 PM
Blue eyes 56
Exhaust System Topics
03-07-2007 02:33 PM
Fat Tony
11-16-2005 10:46 AM
Quick Reply: oil drain plug location on 85 flht
