The Right Way to change your sporty's Oil Filter
Well went to change my 05 sportsters oil / filter for the first time today and I thought I would share my experience with you guys. Draining the oil is a no brainer. Pull the tube down from the frame, remove the plug and drain into your oil drain pan.
The Filter is another story. I'm thinking how do I get it off Without getting oil all over the front of the engine and frame. Well first I took a 10x10 piece of aluminum foil and put it under the bottom of the oil filter as far as it would go and then formed it to the contors of the motor so if any spilled it would get on the foil and not my motor.
I then took a piece of simple poster board about 10x16 and folded it into a half moon shape and slide this up under the oil filter as far as I could get it with the Other end of this " valley " pointing into my oil drain pan. Took my oil wrench and slide it on the end of the filter and loosned it just a nudge.
Once it was losened I simply uncrewed it as fast as I could to get it off. I'm SO FREAKING GLAD I did this.
The Reason being once I broke the seal between the motor and the filter I had about 4 to 8 onces of used oil come running out right down my cardbord valley right into the drain pan instead of on my motor & Frame.
Once I had the filter off I pulled the cardboard out and looked at the aluiminum foil underneath. It had oil on it too. Not much but too much to be on the engine. Pulled the foil away and you know what. I Didnt have A Single Drop of Used motor oil on my engine. Thats right, Not a Single drop. How's that for Slick
I then stuffed a rag in the opening while I got the new filter ready. I did this by pouring fresh oil into the new filter untill it had soaked it up and there was just enough left so it wouldnt spill when I tipped it to screw it on. No fuss and No Mess. I'm dam proud of myself if you must know. Buttoned everything up and test rode.
To all of you who went to spin off your filter and had Used Oil run all over your nice engine, Well sorry man I know it must have hurt and been a major cleanup job.
L8tr
LV
RE: The Right Way to change your sporty's Oil Filter
That's the long way...
Just take it to the dealer and it gets done magically while I wait. [sm=smiley36.gif]
Of course, it's easy for me to say because instead of getting store credit I got regular scheduled maintenance thrown into my deal when I bought the bike. Agree on the price and say, "now throw in the 36 months of maintenance and we got a deal." [sm=goodidea.gif]
ORIGINAL: 12Stones
Nice
Lordvngr,
Harley actually makes a peice of plastic that does the same thing. Good for you for figuring a way around it. That way you can give them money for something you can actually put on the bike.
We can start calling you the helpful hardware man.
David
David
Stones,
My brother got the same deal through his dealership...mine nearly laughed at me.
Good for you!
[sm=icon_cheers.gif]
Mac
Good for you!
Mac
I change oil in bikes all the time, both mine and customers. Since time is an issue, I dont worry that much about oil running down the front of the motor. A can of carburetor cleaner will quickly clean up the mess from the filter.
ORIGINAL: Sincecrazy
Mac
ORIGINAL: breaknbad
Lordvngr,
David
Lordvngr,
David
LV
LV
Carb cleaner wont hurt the finish on your motor or frame, however I wouldnt recommend getting it on your finish paint or plastic parts. Lordvngr, if you are that **** about your ride you should do the work yourself, nothing is more unprofessional than to have motoroil run down from a poorly placed oilfilter on to your delicate motor.
