Oil Archive (no new posts) An archive of oil related questions and comments.
Transmission Oil Change Question
Old 04-10-2013, 07:51 PM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
Default Transmission Oil Change Question
I am planning on changing my transmission oil soon so I got out the Dyna Service Manual and reread about how to change all 3 oils(Engine, Primary and Transmission) - why do the instructions for changing the transmission oil do not have you warm up the engine prior to changing like you do for the engine and primary oils?
Old 04-10-2013, 08:03 PM
target64's Avatar
target64
target64 is offline
because the transmission is not turning inside. there would not be and resistance which makes heat until the transmission is engaged. and if bike was left setting for a few hours all the oil is in the bottom of the case. just remove the plug and let it drain. and add 1 qt new oil.
Old 04-10-2013, 08:14 PM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
Still not sure, I know for the engine oil you want all the contaminants stirred up from running the engine so they run out with the oil before they settle - is this not applicable with the transmission? Thanks.
Old 04-10-2013, 08:22 PM
target64's Avatar
target64
target64 is offline
its a sealed unit separate from the engine. there is no internal combustion containments that can get into it. when you drain the oil it will look new, or might have a little gray color to it from the gear break in contact . that's normal.
Old 04-10-2013, 08:25 PM
target64's Avatar
target64
target64 is offline
I install amsoil 75w90 severe gear oil in mine.
Twisted Humor
09-23-2022 01:31 PM
tnichols
17
05-31-2018 08:18 AM
Jaymac3772
07-12-2010 04:11 PM
SCS
01-05-2007 01:02 AM
Patch
08-01-2006 02:02 AM
Quick Reply: Transmission Oil Change Question
