Clear coat a tank decal
I am waiting on getting a tank back that is being painted by HD with the spectrum metal flake paint. I will apply a tank water slide decal to the new tank. My question is do I have to clear coat over this decal? If so what would happen if I do not clear coat it? Thanks.
Received 47,791 Likes
What do you all thunk of this. I will tape around the decal with about a 1/4 inch space between tape and decal. I will spray it with a spray max clear coat. Anyone ever use spray max? Does this sound like a good plan? I am a novice. The tank was just painted by the factory, spectrum metal flake.
If you're going to clear over the decal I would recommend reclearing the whole tank. If you mask off a section and just clear it, it will be difficult to blend that with the rest of the tank. It could be done but will take some time and expertise in blending. It would be quicker and look better to do the whole tank.
