Trouble getting bike into neutral
Just recently installed a FM107 engine upgrade and updated the clutch spring to the heavy duty clutch spring from Barnett. The trouble I'm having now is when at a stop the bike is nearly impossible to get into neutral. I have adjusted the clutch at the basket tightened bolt till just barely snug and then backing it out 1/2 turn. I also have adjusted the clutch cable till the clutch begins to grab about 3/8 of an inch off the grip. Running mobile 1 full synthetic in the primary. What gives? What am I missing? Thanks in advance guys.
Thanks for the update. There are far to many that ask for opinions/help and then NEVER come back with what the actual solution was.
Ridetothehill (11-28-2019)
blackdresser
06-06-2011 08:39 PM
