tranny life
tranny life
Does anyone have any data / info. on how many tranny failures occur? Wondering how many miles I can expect out of my five speed. It has 108K now and it is the only part of the bike that hasn't been replaced or rebuilt. I have run Red Line Heavy Shock since it was new and changed every 5k or so.
Thanks
Thanks
I would recommend a bearing, seal, gasket rebuild at 100k. Not that hard IMO. I did mine a years ago.
https://www.hdforums.com/forum/prima...y-rebuild.html
The sorts of failure that may happen are a broken internal spring, leaking seal, worn out bearing. On the other hand there are bikes that have done much bigger mileages than yours. It's difficult to answer your query as failures are not very common! You can either ride until something prompts you to act, like oil under the bike, or talk to a local indy about a total rebuild, including all bearings, seals, etc. I suspect the cost of a rebuild will prompt you to leave it for a while!
