Gearing and sprockets??????
I like to take my 77 Ironhead to motorcycle rodeos I would like to be more competitive in the drag race! My question is If you reduce the sprocket in the front and more theeth in the back dose that shorten your gear and if you get a taller gear would you be shooting yourself in the foot? We are racing under 100 yards in the dirt! I would like to pull a wheelie off the line and still have enough to make it to the end with out shifting! I do not care about top speed on this motorcycle
Front = 32T
Rear = 70T
Ratio = 70/32= 2.1875
Front = 30T
Rear = 72T
Ratio = 72/30= 2.400
The higher ratio will get you from point A to B quicker; that should answer your question. You will have to figure out a front/rear arrangement that works for your intended purpose. I don't think you are going to be pulling any wheelies in dirt.
Faster and longer in first gear are mutually exclusive; cannot be done. The lower the gearing is the higher the rpms are in any gear. How long you can go in first gear is a function of the maximum rpms your motor can spin without blowing up or hitting a rev limiter before you have to shift. I would be concentrating on second gear.
Changing either sprocket, front or rear, may also require altering chain length. Fitting a smaller trans sprocket will involve shortening the chain, while increasing rear sprocket size will require a longer one, which is why the front is the best place to start!
Rodeorookie
08-27-2015 04:49 PM
