First Gear 'Bang"
Thanks, but the question remains can you sell me one?
For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Just had my 91 evo in the shop for a 5000 miles service. They replaced the transmission sprocket with the wider upgrade kit. Now I have much more clunk upon shifting from N to first. Not sure if it's the change in the fluid, new parts or poor clutch adjustment causing it.
Do the clutch starting under the derby cover with 3/4 back off from zero play. Be sure to screw in in two to three turns past no play to deburr thread and then the back off. Then, make sure your lever only has about 1/32 free play with the cable length adjuster. What is a 'transmission sprocket with the wider upgrade kit'??
