Trans oil level on a lift is.....
What's the correct trans oil level on a 2012 6 speed touring when bike is level up on a lift? I'm surprised to see no indications on dipstick for jiffy stand or up right level marks like on engine dipstick.... Strange!
Appreciate it!
B Bop
2012 FLHR (Road King) Ember Red Sunglo & Merlo
Cruise Control, ABS, Chrome Aluminum Profile Laced Spoke Tubeless Wheels, Security Package, Saddle Bag LED Lid Spoilers, and an array of accessories that enhances nostalgic appearance & blood curdling performance.
Great spirits have always encountered violent oppositions from mediocre minds.
Appreciate it!
B Bop
Bottom line: Can always wait until everything else is completed and when my scoot get's back on the ground then will check trans level on jiffy stand.
Was just changing all my oils at one time, and wanted to get that task completed, that all.
Appreciate it!
B Bop
I poured approx. 3/4 of a quart of Red Line Shock Proof in trans showing no oil on dipstick as I currently have no reference on lift, when my cam upgrades become completed will return back to ground checking trans level as per service manual outlined above.
If I could steal my wife's measuring cup, can pour out 4oz into measuring cup, the rest into trans, done! Buuuut if she found out I committed this atrocity she will hide my beer!!! Not a good idea....
B Bop
The beauty of the Second Amendment is that it will not be needed until they try to take it.
Leave the 3/4 quart in and when you've finished on the lift set the bike on the jiffy stand on level ground and check the level by resting the dipstick on the start of the threads as per the SM. Adjust the fluid level to between the add and the full marks. Post a pic of your dipstick and we can point out where the add and full marks are. Perhaps you should also place a strip of masking tape across your ignition switch and write "do not start, check oil" on it. I've got a couple of different sized and scaled measuring jugs that live in the shed. Should be able to find some at the dollar shop. I prefer to keep my chemical and foodstuff utensils separate.
OP says there's no marks on his dipstick. If it's HD, it might not have the words "add" and "full" but there will be indication marks.
It's my understanding that '12 touring models the trans fluid level is to be checked with the bike on the side stand, dipstick resting on top of trans threads.
It's my understanding that '13 touring models the trans fluid level is to be checked with the bike on the side stand, dipstick screwed in until o-ring is touching top of trans threads.
That little change in procedure will affect capacity but I'm getting off topic.
The 28oz thing is just to get you close, then top it off according to the dipstick, MY12 bike on jiffy stand and level ground. Guess I just blew away my discount
32oz capacity. I interpret the text in your pics to mean to add fluid until you reach the amount of 32oz, not drain and then add another 32oz. There's going to be some residual fluid after draining. Pour 32oz into a new, dry trans.
Can't understand why the procedure would be different, it's the same case (same capacity) same dipstick. Maybe Harley got it wrong in the first place and changed the procedure to fix their Foxtrot Uniform Charlie Kilo Uniform Papa.
