Primary Drain Plug
RE: Primary Drain Plug
ORIGINAL: Gundog
You didn't specify which bike, but I'm going to disagree with Scout.
I think the size is a standard 1/4" allen or a 5/8" socket. At least that what it is on my bike.
Joe
Thanks guys,I tried the T30 and it seems a little sloppy so I tried a T40 and it seems to fit better but the last time I had it serviced was by the dealer and they must of really torqued it.I'm doing my own oil changes now and the primary is the only spot I haven't done yet.I ride a 2003 Lowrider and never torque drain plugs.I just hand tighten them and have never had any problems with leaks or torn o-rings.It's just too easy to strip these things,I'd sooner just spend a few moments after a couple of rides and make sure everything is tight.I have the service manual and even it doesn't tell you what size the primary drain plug is.H.D. doesn't want you to do anything on your own LOL.
Darryl
Darryl
This is what's used on my '03 Softail FatBoy;
(Also, these are slightly tapered, and you can't torque them down with too much force. If so you can strip the threads, or even end up with the plug inside the case. They recommend seating them until there is approximately 1/16" of the plug sticking out from the case).
primary drain screws changed a lot, but has NEVER BEEN A T30!!!
first was a 3/4 hex head, then a T40, then a 3/16 allen, and now the standard 5/8 hex/ 1/4 allen
P.S. the pic you show of a drain plug says 3/16 allen, but if you look at it, its a torx.........LOL, where did you fish that pic from??
