Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Evolutions Industries 30 tooth sprocket
Old 12-02-2007, 07:56 PM
treeextractor's Avatar
treeextractor
treeextractor is offline
Default Evolutions Industries 30 tooth sprocket
My New Mod
Old 12-02-2007, 08:03 PM
Dalton's Avatar
Dalton
Dalton is offline
Default RE: Evolutions Industries 30 tooth sprocket
I keep looking at that, but am a bit leery of completely eliminating the compensator. Have you ridden it yet, how does it feel, both from the increase in useable torque, and from the engine impulse standpoint. Engine feel as smooth or any other observations? Is the gearing now too tall, I was thinking more along the lines of a 32 tooth sprocket but they dont make one.
34 tooth (stock)= final gearing of 2.79
32 tooth = final gearing of 2.97
30 tooth = final gearing of 3.15
Old 12-02-2007, 08:22 PM
treeextractor
There is another 300 rpm. You can feel the toque transfer, very slight vibration in lower gears (this is without IDS)but very smooth in 6th.Pulls hardin 6th at 60. Cruses 70-80 in good power band for my stocker.Lot more responsive in all gears, seeminglylot more torqe,HonestlyI love it...
Old 12-03-2007, 01:08 AM
Dan B's Avatar
Dan B
Dan B is offline
I've heard that they are working on a 30 t comp sprocket and that it should be available soon.
Not sure if this s true though.
/Dan
Old 12-03-2007, 03:43 PM
rbabos's Avatar
rbabos
rbabos is offline
Who are they? If it's Harley you'll never see it.
Ron
Old 12-03-2007, 03:48 PM
rbabos's Avatar
rbabos
rbabos is offline
treeextractor: The Evolution site says 500 rpm increase. Did you varify the 300 with a tach on the bike. 300 I can live with but 500 makes me want to hold on to the 34 tooth. Forgot the formula for figuring this out with math. Anybody out there a walking calculator?
Ron
Old 12-03-2007, 07:27 PM
treeextractor
Latus HD calculatedat at300rpm . I am not sure how they calculated it but I believeit depends on the gear your in and 300rpm isthe calculation for 6th gear. I am running small tires too 190/50and this set upworks for me on my dyna. Most of my riding is at 60-65 mph in 6th gear. But it performs best perrs around 75mph with plentyof throtle tospare.
mrbreezeett1 (02-01-2020)
Old 02-02-2009, 06:15 PM
treeextractor#2's Avatar
treeextractor#2
treeextractor#2 is offline
bump.....
Old 12-15-2012, 09:09 AM
twistedc's Avatar
twistedc
twistedc is offline
4th Gear
I had a local hd dealer install a evolution 30t comp sprocket set on my 2012 FLHX I need to know what gear they dyno tune in is it 5th or 6th my spedo is off now bike is doing 65 when spedo reads 60. i never got to look at the sprocket they installed just going off the part #.
Old 12-15-2012, 04:20 PM
djl's Avatar
djl
djl is offline
Received 2,031 Likes on 1,499 Posts
Don't know about the later models but the early model speedo reads from the counter shaft. Changing primary gearing did not effect the speedo; only changes in the secondary.
mjpoerp
Milwaukee Eight (M8)
05-16-2017 12:48 PM
JimGnitecki
03-08-2014 05:11 AM
jsw5555
01-09-2010 08:41 AM
azaflacguy
04-02-2009 12:09 AM
Dalton
21
02-22-2008 12:52 PM
Quick Reply: Evolutions Industries 30 tooth sprocket
